What Size Are Standard Speakers?
As per title, what size are the standard speakers in the front in the IS200? I've got some Cerwin Vega components which I've had for a while but never got round to fitting them in my civic so was thinking I may fit them in the lex when I get her on the road, if not then I'd be selling them.
The space in the door is quite big and will go upto 7".
Originals are 6.5" (most speakers are listed in inches not cm so that may make it a bit easier)
If you are fitting decent speakers then it may work out better to make an MDF mounting baffle as it will make the speaker sound better..
Any incar system is 30% equipment 70% installation
