Is 220 Noise And Vibrations On The Sixth Gear
The strange noise and vibrations appear when I drive on the sixth geat and the speed is between 100 and 150 km/h, when I speed up to about 160 everything comes back to normal.
I’ve told this to the technicians and they admitted the problem existed but had no idea how to fix it.
Maybe someone of you have met a similar thing.
i had this problem about two years ago,my dealer said that the problem was the rear axle bush,i new design of bush is fitted and problem solved.the dealer said it is rear axle off and a four hour job.
happy new year.
