My Project Ii
Yesterday was K-SPORT Day
Disassambling the stock brake system
We had to cut off the cooling plates, since it was too extensive to
remove them on the rear side
Comparing stock brake system vs. K-Sport front
Comparing stock brake system vs. K-Sport rear
Installing calipers, putting some grease on the shoes and install
Checking brake system, getting all the air bubbles out of the brake lines
FINISH!
front
rear
I also took some time for the cooling panel :)
  • Replies 87
  • Created
  • Last Reply
Top Posters In This Topic
i know...
maybe put some bigger tyres on to get more traction ?
btw
lovley car!
Yes right, more traction is a MUST right now!
I will look forward to do something in that direction. ;)
i know...
btw
lovley car!
Wider wheels bro!
:D
wide arse arches :D
Yesterday was christmas day :)
Finally I have received my V160 swap kit, everything is brand new and
ready for install.
Some small modifications have to be done, but we will start soon with the install.
Getrag V160
Shifterbracket
C's Shortshifter
OS Giken 1.5 way LSD
RPS Max Clutch with 6-paddle Solid Hub (TQ 825lbft) & RPS Cyn-R-G Segmented Flywheel
  • 4 weeks later...
YESTERDAY WE WERE ASSEMBLING THE V160....
....and noticed that some parts are still missing *gg* :P
Clutch Fork
shifter bracket
Well, that for I'd like to find some solution
--> My plan is to have just ONE clutch line to from connector to the slave cylinder
OK so far I didn't read the V160-thread on My.IS very well,
then I would have known to order the Supra tranny rubber-bracket :yawn:
OMG a new V160 was that direct from Toyota ? That must have cost a bloomin boom, will be nice to get away from the auto though, there for wimps LoL
I have received a whole V160 Swap Kit from PHR which fits direct on the IS300,
but I'm not driving the A/T model, mine came from America with the W55 5-speed tranny. ;)
  • 5 months later...
Hi mates... just want to let you know what happened to my IS300 Turbo meanwhile...
Our Workshop...
The Crew.... (they don't even have a driving licence *haha*) :P
(those just were some kids hanging around, working on their motocross bikes, helping out a little on race car modifications and stuff)
Our Shop has been in perfect situation
Down there was a professional machine-shop, they can do everything
out of a piece of metal, next to it some supermarket to buy food
Another Tools-Market on the other side!
Preparing everything for the removing of the W55 and the Torsen Diff
First off, to remove the exhaust section
W55 & drive shaft removing
Same with the Diff
Differential Disassembling
OS Giken vs. Torsen
Well OK, some of my crew members didn't even have the size to get upward
the car's height :hehe:
longer wire required
Clutch assembling
It's a sport's clutch *gg* :rolleyes:
everything into the tranny
We had to widen the upper left hole, to make the bolt fitting
It was much easier to lift it up and put it to the engine than the W55
bolting on the clutch
Slavecylinder install & covers
Adapter brackets for the tranny cross member
Placing the differential
1-piece driveshaft
fits
That's what I call a ShortShifter :whistling:
ALL IN ALL.... B)
3" exhaust system (non-cat)
This time we had some better tools than for my old exhaust system
Remove weld residues
step by step we're going backward
Once I had some steel catalytic converter.... seems it got shredded... :crybaby:
coming to an end
The last piece of exhaust has to be created to fit correctly
Here we go
Installed... :)
Videos:
Differential Installation
some words to it: I have brought it to my Lexus Dealer to install
the Euro spec IS300 A/T final gearing (1:3,58) in my US spec IS300 M/T (1:3,72) diff housing, including measuring and stuff...
It is soooo awsome!! :cool:
The gears of the V160 feeling now like the 5-speed, simply PERFECT GEARING!!
Oil & Servo Cooling System
Custom, Custom, Custom...... building clamps.... :blush:
Connectors for the Servo Cooling
Clamps got fitted to the crash bar
Finish..... but it was a bloody job, since there is no space to work with :suspiciou
in the front: feft side --> Servo Cooler / right side --> Oil Cooler
...and everything is sealed, there is no leaking :)
Well the stock 5-speed shifter leather sack couldn't be fittet on
the C's V160 shifter, so I had to do something
before...
I have brought the stock leather sack to some saddler to create some new custom shifter sack fitting on the V160 stick
black with silver seames B)
Well, it really looks like a "Very Short Shifter" but it it OK and very nice to drive
Once a time I will have to renew the chrome ball on the top
