Intake Pipe Thickness
Its approx 1,5mm for the tube wall, and approx 61mm opening for the carb fitting/silicone bend that fits to the carb itself?
If your fitting it to the carb i'd go for a 63mm silicone 90 degree pipe and 60mm tube, which would give you enough room to tighten the clamps and fit the pipework,
