Any Battery Issues I Need To Be Aware Of?
As it's getting a bit nippy and there was a slight drag when I started this morning, I was planning to stick my Battery on my Optimate charger overnight. Do I need to disconnect it before I do this (the Optimate is designed to stay on a Battery for as long as is necessary and does my motorbike in the winter a treat) for any bizarre or obscure reason?
As it's getting a bit nippy and there was a slight drag when I started this morning, I was planning to stick my battery on my Optimate charger overnight. Do I need to disconnect it before I do this (the Optimate is designed to stay on a battery for as long as is necessary and does my motorbike in the winter a treat) for any bizarre or obscure reason?
Your better taking it off, as thay may be small chance you may damage your ecu :D
You may just want to cable tie your terminal leads out the way, then charge in situ if you really must.
Please bear in mind Batteries will give of a small amount of gas when charging, so if it has some kind a cover
you need to remove to allow it to vent, you are probably better off removing it from the car.
Cool, this is the kind of info I was after.
Once again, I bow to your wealth of knowledge! I love driving my Lexus but when it comes to tech stuff I need your support!
Petrol. Does it go into that hole thingy on the side? :hehe:
