Two Questions, Reverse & Door Open Light
gents...
2003 IS200.
two quick things that have been at me.
1) there doesnt appear to be an option to turn on the light on the inside when the doors open, only an on and off for the driver/passenger side. bit unusual for a car ?
2) when i put the car into reverse it makes a beeping sound like a truck does ! i had to get someone to jump out to make sure that noone outside heard it... tell me thats not standard ! :)
I could say it's not standard but I'd be lying - and no you can't disable it :lol:
i hate the beeping too but to be honest if you play musice its not that bad, and after all my whinging i also have put it in reverse by mistake!
as for the interior light, on the roof the switch has 3 settings, push it towards passenger door and its on perm, middle is off, and towards driver door is on when doors open
right how embarrassing would it be if i said that i went out and sat in the car, put on the lights to verify that there wasnt a switch, got the manual out (which i should have had in the first place) and found out there is a light in the miggle of the roof not only the personal lights. ack !
What will i find out about the car tomorrow ! :)
