Failed Mot On Gs300 Mk 1
hgvpete
Hi all!!
Just had my gs300 mk1 1994 mot'd and it failed on what the test station vac leek.
This what happens:
If you turn off the engine with your foot pushed down on the brake pedal, the pedal then comes up.
The MOT station failed it because they say there is a vac leek.
But if you pull off the vac pipe from the servo to non-return valve it hisses.
can any body tell me if the pedal coming up is standed or have i got a problem.
