Tps Set Up
legendswraith
Just wondering if one of you fine fellows has a reference guide for setting up the Throttle position sensors. Its for a VVti aristo but i would imagine the 2jz-ge is near as dammit.
Problem is its not jsut plug play and tweak they need setting up with a multimeter etc i just don't know what values i should be expecting and going striaght off the rev range doesnt work
Cheers
Austin
ive got a set of workshop manuals for the 2jz gte, there is a bit in there that tells you how to setup/check the tps, i used this after i stripped and polished the throttle body, i'll go dig it out as its at my other garage..
