Electrical Problems
Hi guys
Got a few problems on the electrical front one being the heated rear window not working, press the on button and no click from the relay anyone know where the relay is so I can check it out?
Others are fuel and temp gauge U/S suspect the faults are connected as they happened at the same time. Temp gauge does not move and fuel warning light flashes all the time, and yes there is petrol in it :lol:
Any help much appreciated.
TIA
Neil
Thanks for that Stevie, I found the main fuse OK and it is fine.
The problem is the relay coil not being energised for some reason not with the fuse. Now I know where that relay is I will need to get the kick panel off and have a good nosey around.
