X300 With Gremlins
hi everyone, i have some problems with my car. i took the Battery off to start another car i needed to move.
now;
the rear windows & passenger windows can't be opened from the drivers door.
when you put the car in reverse the rear camera displays white with flashing dots.
the sunroof has lost its closed position (it wont stop at closed, it goes straight from sliding to tilting).
everything else seems to be ok, i dont have any engine warning lights on etc.
should i just remove the Battery and try to reset, or does the car need a trip to the dealer?
thanks for your input
I am not sure of the correct procedure but I remember reading here about a "reset" procedure for the windows and roof.....have you looked in the owners manual? If not do a search here and on the USA forum.
hi, thanks for your help.
the windows are now fixed, the camera still doesnt work, and the sunroof wont centre, i couldnt find the procedure for that, so just tried all the way back, all the way forward.
going into camera diagnosis on the hidden menu makes the screen freeze.
There is exactly the same query on the USA site.....the answer appears the same, they told him the reset procedure is in the owners handbook, unfortunatly I am at work now so cannot read mine, have you a handbook there?
