There are some on eBay at £35.00 but no idea of quality but maybe worth a look as there is a contact number to discuss.
Item # 350154582088.
As for the fuses which year is your LS?
I don't know if they are the same for all but this list is for the series 2 1992-1994
There are 3 rows of fuses each with 5 fuses.
Top row left to right
#1 25A stop lights,cruise control system cancel device.
#4 15A Radio,power aerial,power door mirrors,air con
#7 10A gauges,reverse lights,auto transmission OD system,power windows,seat belt warning lights
#10 7.5A indicators
#13 15A tail lights,parking lights,licence plate lights
Middle row L to R
#2 15A fog lights
#5 15A cig lighter,alarm,shift lock system,SRS
#8 7.5A charging system
#11 15A heater/air con,rear demister,electronic cooling fan
#14 7.5A instrument panel lights,AC control system,clock,glovebox light
Bottom row L to R
#3 15A srs,ABS system,cruise control
#6 10A outside door mirror demister
#9 15A cruise control,power steering control,shift lock sys,ABS,power door locks,auto light system
#12 20A wiper,washers,headlight washers
#15 10A alternator warning light,fuel inj sys,cooling fan,SRS
There are also 2 fuses to the right the top one is #16 7.5A starting sys,cruise control,fuel inj and intrument lights the lower one #17 15A is for the traction control system if fitted.
1st gen cars are 1989-1994
2nd gen cars are 1994 1998
so 92/94 car is a 1st gen/series.
Gary.
Are you saying that after all my hard work listing the fuses it is all wrong because I put the incorrect series /gen on the post?
