Windscreen Washer Not Working
SeanDB
First post here, so apologies if it is in the worng place, nor could I find a previous post on the following;
I have a IS200 SE and the washer is not working or making a pump sound.......could this be the fuse? I have had a look but cannot determine which fuse it could be.....
Any advice appreciated
Yes, it might be the fuse. The fuse is in the driver's side fuse box (by your feet, in a side panel, the inside of the lid tells you which fuse is which).
Try swapping the fuse and see if that makes a difference.
Sounds good, thanks for your help, will let you know how it gies tomorrow.
