Solar Charger
Chosen One
On my last car (Ford Scorpio Ultima) the Battery was prone to discharge due to all the electrics of the car so I fitted a Solar battary charger to the rear parcel shelf and rather than pluging it into the ciggy lighter socket I connected it directly to the Battery which is a standard option, I also fitted a switch in the circuit incase I needed to isolate it, although the panel did have an inbuilt cut out, this action proved successful. My question is can this be done to a Lexus so as to avoid a flat Battery when left for weeks and even having to run it every so often.
