A while back i purchased from lexus a new fuel filter, and i'm going to replace mine soon. When I opened the box just recently I realised that there were no washers which came with the filter. I vaguely recall (but i'm not 100% sure) that when i replaced the fuel filter last time (which was an ADL blueprint one before) it came with gasket washers for each end of the in-line filter.
If somebody has replaced one, could you confirm if the fuel filter should come with washers at either end ?
mine is the UCF20 model where the fuel filter is located near the rear diff.
Thanks.
Thanks Steve. That makes sense. One side of the filter even has a slight rimmed groove which is probably to hold a washer. I'm guessing if i go to my local car accessory shop it should be one of those thin copper ones, one on either side right ?
