New Sound System....
Changing the headunit isnt too hard - especially if you know how to use a voltmeter. I chopped all my cables but kept the old plugs, some people buy harnesses...
The thing with chopping the cables is that i had to manually find which were the speakers again - so instead of using the inbuilt amp i've just gone directly from the headunit to the speakers in terms of connectivity, i believe it sounds much clearer this way.
I've only changed the rear speakers to the infinity reference 6x9's, and added a kicker solabarick 12" sub and a kenwood amp. You'd be surprised how well it sounds - you dont need any more unless you dont like your eardrums!
So, either get a harness - which is easy to wire up, or if your confident chop and use a voltmeter - easy as pie!
