Longer Sc Connection Hoses
hi all,
i am after some of the silicone tubing for the sc kit - anyone selling up 4 some reason or where is the best place to buy the tube kit (apart from TDI)
might be after some clamps as well but maybe i can borrow some from work :whistling:
Here you go:
4x50mm Clips
10x60mm Clips
1 x 70mm wide by 80mm long = airbox to charger
1 x 60mm wide by 160mm long = lefthand side joint pipe going to intake
5 x 60mm wide by 100mm long = from charger to/from intercooler
1 x 50mm wide by 50mm long = bypass valve
1 x 50mm wide by 90mm long = bypass T pipe joint
Heres the link: http://www.lexusownersclub.co.uk/forum/ind...hl=silicon+pipe
Also i'd seriously suggest the Mikalor clamps over normal worm drives.
