Scatches On Bumbers
i have a scratch just on my driver side door that i made by accident with the car key :( its only a light scratch about a inch. Im tempting to use the touch up kit but i have no idea the best way about it. Any tips?
T-Cut or any good Rubbing Compound will do the job. Use a white cotton cloth, an old t-shirt works best and work in small circles. It will work miracles. Cover the affected area with wax after using rubbing compound.
I have found for all scratched the best stuff to use is "G4", its expensive at about 7quid a bottle, but it really is worth it, i baught my IS200 with a key scratch, running from the frot wing to the back door, and with this stuff it polished right out, other T-cutters wasnt even touching it, i can recommend this stuff highly enough as it works by blending the paint outside the scratch into the scratch giving it a pefect finish.
