Amp Bypass Help Needed
Garysean
If you've got an S model then you don't have a separate amp, so you don't need an amp bypass cable. But you do still need an adapter cable to be able to plug the standard head unit ISO wiring into the Lexus wiring. Looks like you've bought the right thing, that's not an amp bypass cable, it is indeed the ISO adapter cable.
