Is 200
johnwilson
Another possibility is the immobiliser. If the car isn't recognising the transponder in the key fob then the immobiliser will still be active at the car will turn over but not start. Does the Security light on the dash go out when you put the key in or is it still on or blinking ? Have you tried with other keys ?
