Ground Loop Isolators
I just recieved a media player the other day from eBay to go in the car and although it works great and I get a good picture etc, I can hear what I'm assuming is alternator whine as it increases in pitch as the revs go up.
I'm guessing a ground loop isolator will fix the problem?
This is the kind of thing I'm looking at:
http://www.maplin.co.uk/Module.aspx?Module...LOOP%20ISOLATOR
Is this the right kind of thing I'm after or is there something much simpler to do the same job?
Have to admit I found it hilarious driving up the motorway watching some erm, questionable content earlier today but it didn't half put a smile on my face :D
Thanks in advance!
I used to have this with the cheaper stereos off eBay,
The ground loop thing didnt seem to do anything. then as soon as i got my Alpine stereo, plugged that in and the whining stopped.
So it seems like its the units internal grounding/quality sometimes. Maybe try earthing the unit?
Can't pal, it's a little media player thing that just has a power connection via the fag lighter socket, nothing to ground unfortunately, plus it's portable as it's the size of a USB HDD (it essentially is but with a DVD player on the PCB).
It's not bad actually, only cost 30 quid, stick in a HDD and off you go, been sat watching Top Gear on the way to work along with something else :D
Seen the place near me has them in for 7 quid so going to give one a go at the weekend :)
it will be the grounding of the unit itself.. try hard wiring it and grounding to the chassis..
it wasnt there before so can only be that or a fault in the audio lead..
