Scangauge Ii For Sale
Steve_D
Hello guys,
One of the last things i've been meaning to sell for quite a while is the ever so useful scangauge II, I had it in my Lexus for 9 months and had it sitting in the box for the last 2 months, so its 11 months old therefore still has a months warranty left (purchased in May 2008 via the group buy here).
Its in perfect condition, works great.
Here's a rundown of the uses it provides:
ScanGaugeII - The 3-in-one Automotive Computer
The ScanGaugeII is an extremely compact automotive computer designed to read and display information about your vehicle in real time.
Simply connect the ScanGaugeII to your vehicle through it's OBDII port using the included cable, turn the ignition key and the ScanGaugeII automatically connects to your cars internal computer - it's that simple
The ScanGaugeII allows you to troubleshoot your own car, read error codes (DTCs), and the conditions present when the error occurred. You can also turn off the "Check Engine" light and avoid those costly trips to the mechanic.
Reads Trouble Codes
Reads conditions that set the Trouble Code
Clears Trouble Codes
Turns off the "Check Engine" light
Tells you when vehicle is "Ready" to pass OBDII testing
Make and store up to 10 rewritable special codes
to send to the vehicle computer
Display 4 gauges at a time from the 12 built-in digital gauges. the information is presented in Real-time!
Fuel Economy
Fuel Rate
Battery Voltage
Coolant Temperature
Intake Air Temperature
Engine Speed (RPM)
Vehicle speed (MPH/KMH)
Manifold Pressure (not available on some vehicles)
Engine Load
Throttle Position
Ignition Timing
Open/Closed Loop
TRIP COMPUTER
Automatically tracks four sets of trip data - Each with 11 individually stored parameters.
Maximum Speed
Average Speed
Maximum Coolant Temperature
Maximum RPM
Driving Time
Driving Distance
Fuel Used
Trip Fuel Economy
Distance to Empty
Time to Empty
Fuel to Empty
More info can be found on their website: www.scangauge.net
On E-bay their selling at £135.00 (postage included) so i'm inclined to sell for:
£75.00 + RM special delivery cost of £7.00 (if paying by paypal there will be a small additional charge).
Cheers,
Steve D
This topic is now closed to further replies.
