Size And Weight Of Arbs
Mr Mole
standard or aftermarket? dont know if the weight will be a lot different but it may be?
i'd measure the standard ones in my shed but i'm in Scotland at the mo for two weeks.
Aztecs just changed his, maybe he has the standard ones to measure?
Could measure my standard ones mate if that will help? i know the TTE ones i've just fitted are about twice the weight of the standard setup? :)
That would help mate, just a guide to the size and weight is all I'm after
So are you going to pop up for a visit then mate ???
Where about are you in Gods Country :whistling:
I'm in North berwick mate.
Working at Torness power station, earning some overtime for the wedding and car (more the car :lol:)
OK mate i'll sort that asap for you :D
:lol: :lol: :lol: Its all for the car :whistling:
Are you working 7 days a week mate or do you get any time off ??
Working everyday mate, *may* have next wednesday off.
My C-One front ARB is a lot heavier (and thicker) than the OEM one. Think the rear one was pretty similar weight-wise.
Yes mate I gather that, but I want to know the size and the weight :winky:
Just measured and weighed the standard ones i have here matey,
The big front one is =
50inch long and 12inch wide to its widest points and weighs 5Kg
The small rear one is=
32" long and 6 inch wide to its widest points and weighs 2Kg
The small one will fit inside the big one if boxed together, and i'd say the uprated arbs i have are at least twice the weight so if you say 14kg for the pair for the uprated set i'd say you were close? :)
