Anti-roll Bars
Bit more info here on most of the arbs matey, from Steviewevie's previous topic :D
Stock
28mm Front
14mm Rear
ARC
Front +216%
Rear +146%
Do-Luck
Solid design
29mm Front (Non-Adjustable) - Front Only
25.8mm Rear (3-Way Adjustable) - Rear Only
Area51
30mm Front
16mm Rear
NO LONGER AVAILABLE
TRD Yellow
30mm Front 49%
19.1mm Rear 99%
LIMITED SUPPLY
TRD Blue
front 28.6mm
rear 16.0mm
Cusco
30mm front F140%
16mm rear R125%
Cusco DR (Track orientated ARB)
30mm solid front +218%
25mm solid Hollow +220%
Eibach same as L-Tuned, and TTE as listed below
28mm Front
17mm Rear 3-way adjustable
Daizen
32mm Front
19mm Rear
Hollow design
Hotchicks
32mm Front Hollow 2 way adjustable +56%, +61%
19mm Rear Hollow 2 way adjustable +144%, +227%
Tanabe
30mm Front F440kg/0.05m
18mm Rear R92kg/0.05m
HKS
28mm Front +130%
16mm or 17mm? Rear +116%
Stillen
30.61mm Front
19.43mm Rear
TTE
28mm Front
17mm Adjustable settings at.. 90mm 105mm 120mm
TRD Sportivo White
28.6mm Front Hollow type
16.0mm Rear Solid type
Intrax
30mm Front
19mm Rear
C-One
32mm Front
17mm Rear
Largus
Front 35.1mm - 140% Stiffer
Rear 27.5mm - 220% Stiffer
High precision seamless pipe
L-TUNED
Front +49%
Rear +99%
DTec
Front 30mm 40% Stiffer (Hollow)
Rear 16 25% Stiffer (Solid)
