Test Your Iq
LexAzur
Testing Your IQ Everybody...Are you clever..?
I am going to ask you three questions.
And you have to answer them instantly.
You can't take your time you have to answer immediately.
O.K.?
Let's find just how clever you really are........
Ready?
GO !!!!!
First Question:
You are participating in a race.
You overtake the second.
What position do you finish?
NOW! See the answer below..
Answer:
If you answer that you arrived first,
then you are absolutely wrong!!!
Cause you overtake the second and
you take his place so you arrived second!!! !!
To answer the second question don't take as much time as
you took for the first question.
Second Question: If you overtake the last then you arrive...?
Answer:
If you answer that you arrived second last then you are wrong
again.
Tell me, how can you overtake the LAST !!!!
The question is wrong! You're not very good at this are
you???
Third Question Subject: *Very very Tricky maths!
Note:
This riddle must be done IN YOUR HEAD ONLY and NOT using paper and a pen.
Try it.
Take 1000 and add 40 to it.
Now add another 1000.
Now add 30.
Another 1000.
Now add 20.
Now add 10.
What is the total? (scroll down for answer)
Did you get 5000?
The correct answer is actually 4100.
Don't believe it? Check with your calculator!
The decimal sequence confuses our brain,
that always jumps to the highest decimals (100s instead of 10s).
That should have you in a bad mood for the rest of the day!!!
U ARE THE WEAKEST LINK-GOODBYE!!!
the second 1.
You can overtake the last person by being in any position and lapping them, slight flaw in the question and the answer however I got the all right
