Sc 430 Remote Roof Control
Gazzer9
Just completed the installation of the "Luxlink" remote roof opener.
Am quite proud of myself!
Took me 7 hours.
I ama dentist, not a sparky.
Works great!
My suggestions:
Use quick and simple snappy "m" connectors, not a soldering iron.
Cut the plastic frame around the fuse book cleanly with a knife, to allow you to peel back the carpet over the foot brake pedal, improving access.
Once done, glue the frame back together.
Use awire coat hanger to thread the wires down into the door, using the wire coat hanger to pull them back down.
Thread the hanger up into the rubber boot from inside the door.
Introduce the wires by opening the little white plastic door and following the top loom down into the door boot.
The white plastic door has a space where the new wires fit beautifully.
Take the rubber boot away from the car frame to find the wires.
The boot has a hole allowing you to thread the new wires nicely.
Make sure you re-position the rubber boot waterr- tight at both ends.
Use cable ties to keep the new wires in the door away from the window. Fix them to the existing loom branch.
Simply make an eye in the end of the hangar and pop the wires in here. For extra security, place some tape too over the wire and the hangar eye.
For any more help, mail me!
Gazzer
Guest inicol63
Welcome to the club...
Great to see another SC430 on here.
Looks like i got to come out to Spain to get my SC430 TOP done lol...
Why not post some pictures of your car...
Post them in SC430 area thread....
If you want get the bit shipped here im sure we can fit it to your car one weekend lol
Rabs
Guest inicol63
Rabs
Thank you mate are you going to JAE because that will be cheaper than going to Spain and getting it fitted LOL
