Is200 Sat Nav System Testing
Rabster
Ok here is the problem i have a screen and i have the diagrams for it worked out its the IS200 Sport Nav screen
from following the diagram i have the following connections made
ACC = pin 14
12v =pin1
GND =Pin 22
Ign sw = Pin 3
red = pin 16
Green = pin 4
Blue = pin 17
Shield= Pin 6
Sync = pin 5
DTX + =pin 9
DTX - = Pin 21
Wired into the 3 resistors and 2 diode circuit to fool it into thinking the amp is present(dont hink its needed but what the hell)
from what i can tell there are no other connections needed i have run a scart wired to RGB output including a seperate sync and still nothing
Form my past work on screens and other toys my assumption is that even without there being an image the screen should illuminate in some way to show power but as of yet there is no signs of life
My RGB output works tested on a 5 grand projector at work :whistling:
This is the second screen unit i have now and the likely hood of 2 units not working are remote but possible but even if the screen was burnt out etc there would still be some sort of illumination or even the fan spinning at the base of the unit but nothing so am i missing something monumently stupid or is it being a pain for the sake of it
at this rate im going to go bald with stress lol
any advice before i torch the thing
Rabs
