This car is making me look bad, I cannot figuew how to get to the stop light to replace it....even with the help of the manual.
And Halfords had 2 bulks listed for the car as well.
Can anyone shed any light.
Head hung in shame ...... never had this problem before
On a series four.
Open the boot and on the side of the light assembly you will still two plastic caps.
Prise those out with a screwdriver, un screw the fastening screws, the unit will pop out and replace the bulb.
Well Ive done it but I wish I hadnt......
One side was glued, and I had to use a socket and wrench to get the screw out, but bulb replaced ok thanks.
When removing the cluster from the other side, its was so stuck on, that even with the screw removed, the plastic recess that house the upper screw tore off the cluster and stayed fixedly on the bodywork.
I'll try an glue it with some waterproof adhesive later.
