Removing Bonnet Prop
ok, now I've got my bonnet struts installed, how do I remove the OEM prop ? The instructions say to "rotate" it (but not in which direction) and to "pull gently". Can't get it out pulling gently. Does just the rod itself come out or does the plastic insert that it slots into in the bonnet come out with it ?
Loving the struts ! :D
