good to hear. did you get a hold of tte black box? hope it goes well for you mate
Not yet, the mechanic suggested that I can use the prolex induction kit I have. He will manage to place the air filter behind the ABS sensor. So I will also be able to use the TDi carbon air induction kit.
tdi dont make them anymore mate unless you sourced a used one.
Yes, you are right. I have one already, it came with the SC kit
good mate. i really want one of those.
Today we continued with the upgrade of my engine. Initially we installed a new clutch, the EBC front brakes and Goodridge brake lines all around, then the DKNE manifold and after we commenced the fitment of the SC. The project upgrade hopefully will be completed tomorrow afternoon with the installation of the intercooler , the induction kit (some work is needed to be done to fit the induction kit behind the ABS sensor unit) and the TDi carbon fiber air scoop. During the week the HKS BOV will be fitted also (waiting for the HKS universal adapter), a new fuel pump and fuel filter.
More pics will be uploaded tomorrow.
The middle bar for the cradle fitted very well! I need to buy tomorrow an inox 60mm tube to and some bending is needed with the bender in order to join the prolex induction kit with the Apexi filter. Pics will follow tomorrow
We used a smaller tube to estimate the bending that is requiered to be done in the 60mm inox tube. The hydraulic oil tank for the steering wheel will be moved and positioned next to the Battery to gain extra space for the Apexi intake filter.
Thanks mate. No there are any problems with my fuel pump. The Lexus mechanic suggested to change it for precaution. Around 120000km some OEM cars found to have problems with the fuel pump. (Mine has 100000km). Since I have upgraded the car he said to change the fuel pump and fuel filter in order to have a good fuel supply to the engine.
right i see. so when you putting this on a dyno?
