Igniter Circuit Malfunction....
  • Replies 58
  • Created
  • Last Reply
Top Posters In This Topic
sorry abou the late reply. ive been doin some more research into this and now people are sayin to me that it could be the MAF sensor??
ok, i got another code come up on the OBDII. cant remember what it is but its something like Mass Air Flow or what not!
I guarentee 100% its not the Mass air FLOW sensor.
Really you need the exact code to help diagnose. If its the Mass air pressure sensor then check the wiring and check the pipes down the side of the throttle body are tight.
Have you not read the advice already given?
have you had the code read yet?
could be an air lock in the cooling system, when mines overheated it just cut out, take the rad cap off run the engine and
try and get any air out the system and see if that helps, also check your coolant levels.
