Li2501-x Turbo Kits
Hai,
Anyone here using LI2501-X turbo kit from NO LIMIT MOTORSPORTS.Com.
Any commen on the item?
Direct bolt on or req mod again to IS200 1G-FE?
How about ECU? need to change or just using Ori
How about other internal engine parts? need change e.g piston etc
Pls advise
http://www.nolimitmotorsport.com/Merchant2...;Category_Code=
Cant see why it cant just be bolted on, would need some fabricating for an oil feed. And the boost would have to be kept low unless you did change the rods.
and it would need some ecu to run the fuelling, and that would have to be proffessionally mapped.
