IS200 3D views
Apologies if these are already well known, but here's a couple of excellent 3D views of the IS 200 (Exterior & interior) that I found. You need Apple's Quicktime movie player to view them, but once open, just click, hold and drag your mouse over the main window to move around. In fact the interior view is still excellent quality if you increase the window size. Let if fill your screen and its like sitting in the car - while parked in Las Vegas!!! :D
Just realised, if you want to be able to increase the window size (as I described above) you'll need to right-click on the links above and select "save target as". Movie will then download to your PC. If you then open it, it should open in the normal copy of the Quicktime player (rather than within a web page). Then go to the "Movie" menu option and select either double size or "fill screen".
Gareth
  • Topics
  • Our picks
      • 0 replies
      • 0 replies
      • 0 replies
      • 0 replies
      • 0 replies
