Sounds like you need to re-initialize the window/sunroof system. Happens if you disconnect the Battery. Do a search on the forum here but i'm sure all you need to do is to go to each window and press and hold the button button down for abut 5 seconds and then do the same with the window wound up.
Sounds like you need to re-initialize the window/sunroof system. Happens if you disconnect the battery. Do a search on the forum here but i'm sure all you need to do is to go to each window and press and hold the button button down for abut 5 seconds and then do the same with the window wound up.
thanks will go and try it now
YES ALL WORKING NOW, THANK YOU
