Help!
my abs is activating everytime just before i come to a stop, wet or dry doesn't seem to matter. I have no abs fault light on, is my ecu shot? brakes are all new and have checked all sensor pick-up rotors. The severity of "buzz" throught the pedal increases along with braking force.
any ideas?????????
oops! 1996 ls 400
Help!
any ideas?????????
oops! 1996 ls 400
Unplug and re-plug all the sensor conectors? and the relevant connectors at the ECU?
I'm in agreement, unplug, clean and replace sensors. Had a similar problem, cut in 'just' before coming to a stop, unplugged both, cleaned and replaced and the problem was no-more :) If it doesn't work, its a good place to start!
