Tracking Brakes Or Balancing
GWilso
Norning all,
I seem to have developed a problem with the suspension or brakes? and need your help
Whilst driving at higher speeds motorway etc when braking i'm getting quite bad vibrations from through steering wheel also causing the brakes to be much less efective whilst driving around town if i'm braking over an uneven suface ie bumps potholes abs is kicking in
whats this likely to be?
Gordon
If it was your tracking/geometry it would be happening while driving along normally (I presume it's fine then ?) and not just while braking. Sounds like a braking problem, probably a sticky caliper IMHO.
Have a look and see if one wheel has more brake dust than on the other side, and if the brake caliper is a lot hotter (careful not to burn your hand !).
