Turbo Stuff..
I have recently noticed on eBay some - apparently - good stuff for the 1g-fe engine, don' tthink that I've seen any topic on that in the forum, so I was wondering if anyone knows/had a chance to try the products from this company here
not cheap I know, but doesn't look that bad, does it?
If one would go the turbo route, will these piston be up for the job? I don't see anywhere being written they are decompressed... :question:
Thats the stuff SPC horsham are selling.
there is a few threads on the various parts.
Dave who used to have the Rotrex setup is having all the stuff fitted so we'll see with his car.
stav
I have recently noticed on ebay some - apparently - good stuff for the 1g-fe engine, don' tthink that I've seen any topic on that in the forum, so I was wondering if anyone knows/had a chance to try the products from this company here
Hi, the forged pistons come with std compression ratio so that they can be used in either the std N/A engine as an upgrade or be used with TTE supercharger kit which fits the std engine. If you are going down the big supercharger or turbo route then the compression ratio may be altered more effectively by modifying the cylinder head. This greatly improves air flow without touching the ports due to the fact that these engines are designed around emissions and supposed economy, not power. If you contact the sellers I am sure they will be able to give you more info or even show pictures.
Edited by janey
