Exhaust Replacment Part Numbers
Anubis
All.
It is time I replace my exhaust on the Toyota Harrier 1998 model. However, does anyone have the part numbers for for parts of the exhaust as I am loathed to go to my Toyota dealer.
Adam
Hi.
Wow. Many thanks for this. It is a great help.
The engine is 1MZ-FE 3L.
Is there a generic lexus/toyota model which utilises the same exhaust as I guess that exhaust fitting centres will not have this exhaust parts and most likely will need to go to Toyota.
Any ideas.
Adam
UPDATE
2001 LEXUS RX300 (MCU15R-AWPGKW) EUR RHD 1MZFE
1998 TOYOTA HARRIER (MCU10W-AWPGK) JPN WG 1MZFE
2001 LEXUS RX300 (MCU10L-AWPGKA) USA WG 1MZFE
These seem to ahve the same part numbers for the exhaust, so could I assume that a Lexus rx3000, UK 2001 exhaust system is the same as my Toyota Harrier 1998 (Jap)?
Are all the parts in the right-hand table (not the diagram) the same ? If so then it's a pretty good bet that parts are the same.
I don't know anything about the Harrier/RX300, but an example from a similar timefame the Altezza/IS200 share a lot of the same parts, including the exhaust system when the engine is the same.
