As A Newb . Why Is This?
Try re-setting the ECU, take out the EFI and ECTS fuses from under the bonnet for 30-60 seconds, just make sure your ignition is off when you do it, you need to get the fault codes read aswell.
Don't take the fuses out before getting the codes read ! Because then you'll lose any codes that might be there.
cheers.i will have a look . shes been parked up for a yr before i gt it ....i have a code reader there . so i will plug it in and heve a go.....cheers for the help
chris
chris
were abouts in scotland you from?matey.
