Uprated Conrods - There Has To Be Someone Out There
Mine is Turbo and has been running at 0,6 bar 270 hp for a long time now ,also has had close to 150 runs on the dyno being set up correctly , Mr Reads runs 385 on std feul system so why wont yours ?
That's pretty good going so far then huh :) What management are you using for it? Have you added a thicker Head gasket to lower the compression?
Completely stock motor stock injectors and currently on Aem management
slightly OT, but is there any palce online where we can see the mods you have done to your 1g-fe to put out that sort of power?
Me think this should give much hope to lot's op people lookin for more power, and considering how scarce s/c are nowadays (plus they're all becoming older, and prone to break I guess)
I wouldn't mind a turbo kit on mine, and 250 hp sounds definitely good! :-)
Sorry guys I'm probably a newbie here, but I did drive supratruck IS200 Turbo and I can tell you something ,it's nice setup.
And you can tell the 270+ bhp are there.
If supratruck let me post few pictures ,I'll do it with pleasure :winky:
Thats not a problem mate if you wish to post photos no problem , My car will be at Jae this weekend
