1991 Soarer Tems Pump
Headhunter
I`m just in the process of aquiring my first Soarer it needs a replacement TEMS pump.
Please can anyone tell me where to find the location of the pump( I was told it is under the bonnet)and,
can anyone tell me how difficult it is to replace i.e. a step by step guide to doing the job ?
Many thanks in advance
Headhunter.
When you say TEMS pump do you mean the air suspension pump?
I have TEMS on my imported Celsior but it is coil springs not air suspension.
I think the way it works on mine is an electrical solenoid system which opens/closes a valve on the damper to adjust the stiffness.
If you need more help you might want to go to the website below as they are more into Soarers.
www.soarercentral.com
