Gearbox Oil Help?
whitelabelboy
ive done a search and cant seem to find much info :(
what oil, how much oil. for a full gear box oil change on a rs200?
ive been into toyota.. they sent me to lexus... between the 2 of them they dont actualy know what oil goes in :S
any help is much appreciated
thanks mate...
off topic.. but according to that site, what the hells an altezza rs180??
No idea- but your car is listed under Toyota>Altezza RS200.
Go to Opie oils- they will tell you what type of gearbox oil you will need.
Altezza RS200 gearbox oil- click me!
DO NOT Trust that web site. You must only use GL4 oil in your J160 6 Speed. All the oils that site list for the Altezza 6MT are GL5.
The only synthetic oils I've found that are safe to use are Redline MT-90, TRD 75W90 & Amsoil 75W90
The reason why you don't use GL5 oil is the Altezza/IS J160 6 speed gear box has brass synchro rings. Most GL5 oils contain reactive sulfurs that cause damage to these synchros. So unless you want to rebuild your gear box in the near future don't use GL5.
thanks for for that info, also has anyone got an idea of how much i will need ?
  • Topics
  • Our picks
      • 0 replies
      • 0 replies
      • 0 replies
      • 0 replies
      • 0 replies
