Help - Need Brake Booster Assembly
TheGuv
My 2001 GS430 has a broken brake booster unit and has been in the local garage for nearly 3 months. BBS Reman rebuild it but it's still broken (See my other thread in the GS/Brakes forrum).
Quite frankly I haven't got the 2500 quid Lexus wants but I've had zero luck on eBay or breakers, so I suppose I'll have no choice. Any ideas??
Can anyone confirm the following? :
47210L is the Brake Booster Assy, W/Master Cylinder; which comprises
47201 Cylinder Sub-Assy Brake Master; and
47070B Pump Assy w/Accumulator
I think from info on the 'net that part 47025-300230 Cylinder Sub-Assy Brake Master which isn't shown on my exploded view is the actual part I need (the master cylinder) which is 600 quid cheaper as it doesn't have the reservoir or pressure switch -- Can anybody confirm this please?
'guv
  • Topics
  • Our picks
      • 0 replies
      • 0 replies
      • 0 replies
      • 0 replies
      • 0 replies
