Door Adjustment?
there is a difference in the space running along the bottom of my drivers door of 2 or 3mm.
because of this the door does not always close first time when i shut it. it also makes a bit of a rattle when shutting it because the catch on the door is not in line with the bit on the frame.
does anyone know if the door can be adjusted?
yes pal your door can be adjusted, if it only has to be adjusted a couple of millimetres then u could either hold the bottom of the door while its half open and give it a good crack upwards,this can usually work or u have to just slacken the top bolts very slighty and lift the door to the correct position and tighten the bolts back up........
