Rear Diff Oil
  • 1 month later...
Just had my diff oil changed, my garage used Shell Spirax 80W-90 so sounds like your tech is correct
hi mate
sorry for sealing your post mate :)
im thinking of changing the diff oil how many liters do i need
thanks
wahid
hi mate
thanks
wahid
just one
hi mate
thanks
wahid
just one
thanks dude :winky:
  • 3 years later...
  • Topics
  • Our picks
      • 0 replies
      • 0 replies
      • 0 replies
      • 0 replies
      • 0 replies
