2004 Rx300 Anti Skid Cutting In
when I go into a right hand corner faster than my granny would drive into the corner the TCS systems beeps until i get the speed down again. No noise when its a left hand corner.
Anyone any ideas? Dont think the power is affected when the tcs goes off.
thanks
thanks
Sounds like it maybe the steering angle sensor may need resetting or has gone down. This is the zero point calibration. If this is set wrong, like if the Battery went flat with the steering wheel turned off centre then that can effect it.
If not then its probably the yaw rate sensor.
thanks
thanks for the reply, are either of these able to be done by a car owner or is it a Le$us garage only?
thanks
thanks
thanks
Think it's best to take it to a Lexus Centre just to be safe
