Fitting A Standard Stereo In A Lexus Is200
peco
HI THERE,
I HAVE A LEXUS IS200 ON A 51 PLATE AND THE STEREO TOOK THE KNOCK! AS I AM AWARE THIS CAN BE A COMMON PROBLEM.
INSTEAD OF FIXING IT I BOUGHT A SONY STEREO TO REPLACE IT,I HAVE SORTED THE POWER SIDE OF THINGS BUT CAN NOT SEEM TO WIRE UP THE SPEAKERS. CAN SOMEONE HELP!!!!
I'M SURE IT HAS AN AMP BUT THOUGHT I COULD JUST WIRE IT UP.
DO I NEED TO REMOVE IT OR HAS ANYONE GOT A WIRING DIAGRAM
how did you sort out the power side???have you butchered the wiring??? :ohmy::ohmy::ohmy::ohmy:
you don't say the model you have s,se,le,sport?? you need an amp by-pass lead mate if you have the amp'd up version you get them from ebay for about £20-30
very easy to fit should take you about 20 mins if not faster.
ps no need to shout,turn the caps off.
Speaker wiring is as follows
OEM Plug Side - Speakers
RH F + = Green
RH F - = Blue
LH F + = Pink
LH F - = Purple
RH R + = Red
RH R - = White
LH R + = Black
LH R - = Yellow
ref http://www.installdr.com/Harnesses/Toyota-Wiring.pdf
Power wiring here http://www.lexusownersclub.co.uk/forum/ind...mp;#entry686374
Like ormi said if you have the factory amp you will need a by-pass lead.
  • Topics
  • Our picks
      • 0 replies
      • 0 replies
      • 0 replies
      • 0 replies
      • 0 replies
