Oem Cruise On Is200 Manual?
lex2oos
sup guys!!!
couldn't find anywhere. is that possible? I found some guy who did this to his toyota, he just pluged the oem cruise switch and installed clutch switch and wolla. I found that lexus has connector for cruise switch under airbag on steering wheel. need to check if clutch switch connector is there. if it is, I dont see a problem to give it a try. what do you guys think?
FAIL or WIN??
ok
i got the cruise switch from a totaled is300 at loco junkyard
pluged in mine - nothing, the light dont lit up :(:(:(
where actualy is the cruise light on cluster? myb someone has a picture? myb just bulb isn't there?
i was looking around toyota parts catalog and found that Auto gearbox lexus has the same gauge cluster part number as the manual, so the cruise light should be there ( i hope ) :(
part numbers were the same for spiral connector, ecu and other things related to cruise...
still hope it is going to work :(
It definitely wouldn't be as simple as getting it and plugging it in even if it could work.
I'm sure it's related in some way to the ECU so isn't simply a plug and play type option, otherwise it probably would have been offered by Lexus themselves.
I'm no expert though, so this is just an educated guess :)
  • Topics
  • Our picks
      • 0 replies
      • 0 replies
      • 0 replies
      • 0 replies
      • 0 replies
