My First Rear End Slide
hi all
well i was coming home from tipton west midlands and i turned in to brandon way next thing know am slideing there was no cars on the road :o
but there was petrol or some thing on the road
it was raining all day today
just before the slide there was one light that was keep on coming on on the dash it was a car with skid marks
somethng like this but in yellow
http://www.racq.com.au/__data/assets/image...rt_64840807.jpg
^^^what doe this sign mean on dash?^^^
thanks
wahid
hi all
thanks
wahid
I believe that is the traction control indicator, i assume you may have also heard a strange electrical clicking or buzzing noise while this light was on??
You’ll this time of the year with it being cold, wet, and all winter like, that, that light will come on more.
There is nothing to worry about, as it’s just letting you know that your tire was spinning, and that it has reduced power to stop you from spinning out.
If you had turned your TRC off, you would have found that your “slide” would have been A LOT worst !!!
Last year, I got a bit twitchy on a motorway with black ice. It set my heart going for a bit, but I was so grateful that we have TRC on our cars !
Wait until we get some ice and snow, then you'll find out how tail-end happy the IS200 gets!
RWD+Low profile summer tyres are a bad combo in snow and icy conditions.
I cant wait for the snow- great fun :duh:
In the GS, the flashing skid symbol means the traction control has kicked in. If it beeps at the same time the stability control has kicked in as well. From experience the VSC only kicks in on aggressive sideways slides - not that I do that regularly :-)
what brand of tyres do you have???
hi mate
i have 225/45/17 bridgestone all 4
thanks
wahid
i have the same and it only tends to slide on 1 particular road that is cobbled at the junction, so when pulling out it does slip a bit but otherwise no issues at all!!!
having wider tyres makes the loading per contact area far less than a narrower tyre so increases the chances of a slide.
check your tyres pressures, read depth/wear and the most basic of all dont floor it! also remember when the temps drop below 7C the rubber of normal tyres starts to harden and you have less grip, if you are having troubles now then i would hate your chances when it does get cold and there is a good frost.
But as yu mention there was something on the road it could well have been diesel and it wont matter if you had good tyres or not - it will cause a slide
  • Topics
  • Our picks
      • 0 replies
      • 0 replies
      • 0 replies
      • 0 replies
      • 0 replies
