Head Lights
ok my headlights are crappy as in they have a sort of film on them as in when lights are of they have ring shapes roung the lights on out side can i get rid of this by t-cut or wet and dry them then polish or is it new lights help please they let them down :question:
Yep a bit of T-cut & elbow grease will work a treat. I've got one head light that's a bit faded on mine also. I've used Mothers pre-wax cleaner on it with good results. Only problem is it dulls again quickly. There are more specific products on the market you could try like Wynn's headlight restorer
I use g3 cutting compound on a wet buffer head. Its a body shop cutting paste more course than t-cut. Polish after to prolong the effect. vauxhall astra and old shape mondeo had same fault works on these models to
