Head Light Washers
lee200
Try pulling then up manually, had my front end painted and they dint work as there was not fluid in the washer bottle, i filled it and still nothing till i pulled the up and heard a gluging sound!!
Now they work just fine, air block or somthing?
my passenger side ( left ) actuator is missing in action and i only have the outlet pipe for water to come out so ihave glued the cover shut!
how do i go about disconecting the power to it and just letting the driver side one work? as im not forking out 100 quid for a headlight washer
  • Topics
  • Our picks
      • 0 replies
      • 0 replies
      • 0 replies
      • 0 replies
      • 0 replies
